Clears the CDP counter statistics.
| ports | Specifies the ports to clear. |
| ports_list | Specifies the port list. |
N/A.
Use this command to clear the CDP counter statistics.
The following example clears the CDP ports counters:
clear cdp counters
This command was first available in ExtremeXOS 15.4.
